Activity Forums Adobe Premiere Pro Exporting an XML whilst using an Ingest workflow
  • Exporting an XML whilst using an Ingest workflow
    Posted by Ben Allan on May 25, 2017 at 12:50 am
    Has anyone exported an XML whilst using a proxy workflow? How do you connect it to the raw?
    Ben.
    Ben Allan replied 9 years, 3 months ago 2 Members · 2 Replies
  • John Pale
    May 25, 2017 at 8:33 pm
    • The Proxy workflow is not supported for interchange options such as Project Manager, Render and Replace, AAF, Final Cut Pro XML, EDL, OMF, and so on. You lose Proxy attachment for these functions. After Effects and Audition interoperability functions are also not currently supported with the Proxy workflow.
  • Ben Allan
    May 25, 2017 at 10:07 pm
    Thanks for the reply. Well that’s good. I was just making sure the colourist can connect to the raw and not the proxy. Right?
