Activity › Forums › Apple Final Cut Pro Legacy › Exporting Alpha Channel
  • Exporting Alpha Channel
    Posted by Jonathan Spencer on April 1, 2009 at 4:19 pm
    I’m exporting a green screened element from FCP to Motion and want to be able to drop elements behind it.
    Question: What format/settings to do I need to use in my exporting from FCP to get the desired effect?
    -Jonathan
    John Pale replied 17 years, 6 months ago 3 Members · 3 Replies
  • John Fishback
    April 1, 2009 at 4:56 pm
    Have you tried Send to Motion. Or you could try exporting using the Animation codec (that has an alpha channel). I’ve never done this as I’d do the key in Motion. The keyer there is much better than FCP’s.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Jonathan Spencer
    April 1, 2009 at 6:01 pm
    Actually, yes I did try that. I tried that first in fact and was happier with the keying in FCP. Primatte is an excellent matting tool but not quite what I needed.
  • John Pale
    April 2, 2009 at 4:58 pm
    You can export with the Animation codec but the clip must NOT be rendered.
    If you render, the export draws on the render file, which of course is composited with the background…so your alpha will not be preserved.
    Remove the background….leave un-rendered. Export using the Animation codec (millions +)
