Activity Forums Apple Final Cut Pro Legacy Exporting AIFF from FCP 7
  • Exporting AIFF from FCP 7
    Posted by David De vos on December 21, 2010 at 4:25 am
    FCP 7.0.1 is giving me AIFC files instead of AIFF upon export. Need them to be the uncompressed AIFF version. Any help as to why it’s compressing to AIFC instead? I’ve looked all over, can’t seem to find the solution. Thanks.
    Michael Gissing replied 15 years, 9 months ago 2 Members · 1 Reply
  • Michael Gissing
    December 21, 2010 at 4:44 am
    You can read all about it here –
    https://en.wikipedia.org/wiki/Audio_Interchange_File_Format
    But here’s the important bits –
    “With the development of the Mac OS X operating system, Apple created a new type of AIFF which is, in effect, an alternative little-endian byte order format.”
    “Because the AIFF architecture has no provision for alternative byte order, Apple used the existing AIFF-C compression architecture, and created a “pseudo-compressed” codec called sowt (twos spelled backwards). The only difference between a standard AIFF file and an AIFF-C/sowt file is the byte order; there is no compression involved at all.”
    In a nutshell, the file is uncompressed aif, nothing to worry about.
    Note: As of Mac OS X version 10.4.9, the system will sometimes incorrectly display the AIFC icon for files with the .aif extension, whether or not the actual file format is AIFF or AIFF-C. This can be verified by opening the files in a hex editor and checking the FORM chunk’s form type. This can sometimes happen when exporting files from QuickTime, and frequently happens when sending and receiving files between Windows and Mac computers or extracting files from an archive.
