Activity › Forums › Adobe Premiere Pro › Exporting a .mov file from Premiere Pro
  • Exporting a .mov file from Premiere Pro
    Posted by Sean Winn on May 12, 2013 at 2:30 am
    I’m a new editor with Premiere, having moved over from FCP7. I”m a little baffled on an exporting situation. I’ve typically exported h.264 files for smaller size, but always as QT mov files. I can’t find any way to do that using Premiere CS5. My sequence is 1280×720 and when exporting a h.264, it only comes out as an mp4. I tried to author a DVD using idvd and it doesn’t want to do it (encoding errors).
    When I’ve chosen to export as a quicktime file from Premiere, the files are huge.
    Is there a way to export a mov h.264 file from Premiere?
    Sean
    Chuar Yapchong replied 9 years, 9 months ago 7 Members · 17 Replies
  • 17 Replies
  • Ann Bens
    May 12, 2013 at 8:57 am
    If i remember correctly there should be an Quicktime option in the Export Settings (under format)
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Sean Winn
    May 12, 2013 at 8:46 pm
    Ann,
    Thanks for the reply, but I’m not getting anywhere. I know about the quicktime option under format. As I stated, when choosing this, it produces huge files. I need a .mov file from Premiere that’s encoded as h.264, but Premiere doesn’t seem to offer this like Final Cut.
    Or, if anyone can tell me how to export a clip from Premiere using something else other than h.264 that reduces the final file size, that would help.
    We use ProPresenter presentation software and it handles the .mp4s out of Premiere fine. It’s when I went to author a simple DVD with idvd, that it wouldn’t encode the mp4s. That led me back to the question – why can’t Premiere export a reduced size .mov file. Again, I’m exporting at 1280×720.
    Any other suggestions or instruction is appreciated,
    Sean
  • Leah Chapman
    May 12, 2013 at 11:58 pm
    A general tip for getting small H264 exports: simply export under the H264 main heading and then change the .mp4 extension to “.mov.”
    Not sure if iDVD will accept that, but it’s a useful trick in other situations.
    Can iDVD accept mpeg-2s? If so, that would be your best course of action when making DVDs.
  • Sean Winn
    May 13, 2013 at 2:11 am
    Thanks Leah,
    Testing a burn with a simple file extension change from .mp4 to .mov
  • Tero Ahlfors
    May 13, 2013 at 7:29 am
    [Sean Winn] why can’t Premiere export a reduced size .mov file. Again, I’m exporting at 1280×720.”
    It can if you lower the bit rate. Also DVDs aren’t HD so there is no use exporting it as 720P. I’d personally export straight to MPEG 2 using the MPEG 2 DVD presets because that’s the format it will be transcoded to by the authoring software.
  • Sean Winn
    May 13, 2013 at 12:14 pm
    Tero,
    Thanks for that info, I was thinking correctly about the DVD and HD factor. Appreciate that.
    Sean
  • Ivan Myles
    May 14, 2013 at 3:10 am
    [Tero Ahlfors] “I’d personally export straight to MPEG 2 using the MPEG 2 DVD presets because that’s the format it will be transcoded to by the authoring software.”
    +1
    [Sean Winn] “I need a .mov file from Premiere that’s encoded as h.264, but Premiere doesn’t seem to offer this like Final Cut.”
    Scroll down to the bottom of the video tab to change the target bitrate setting.
    [Sean Winn] “I know about the quicktime option under format. As I stated, when choosing this, it produces huge files.”
    The highest bitrate QT will produce for H.264 is about 20 Mbps for 720p24, and 25 Mbps for 720p30 (when key frame distance=1, Quality=100, and bitrate is unconstrained). The settings can be adjusted to get smaller files.
  • Sean Winn
    May 14, 2013 at 1:05 pm
    Ivan,
    Thanks for the reply. Where do you suggest I set the bitrate – or is the picture what you’re suggesting (6000)?
    Thanks – Sean
  • Sean Winn
    May 14, 2013 at 8:05 pm
    Another question – in your image you show quicktime, h.264, 1280×720 (linked). When I set it to quicktime, h.264, and change the size to 1280×720 (while linked) it won’t accept it and changes from 1280 to 1080 for example. I can only get your pictured settings by unlinking the height & width.
    Thanks for any info on this plus my last question about the bitrate.
    Sean
  • Ivan Myles
    May 15, 2013 at 2:05 am
    [Sean Winn] “Where do you suggest I set the bitrate – or is the picture what you’re suggesting (6000)?”
    Yes, click on the the orange text (default set to 6000 mbps) and enter the desired target bitrate.
    [Sean Winn] “When I set it to quicktime, h.264, and change the size to 1280×720 (while linked) it won’t accept it and changes from 1280 to 1080 for example.”
    This happens sometimes, usually when changing the aspect ratio. Just unlink and set the dimensions as required.
