Activity › Forums › Adobe Premiere Pro › Exporting a .mov file from Premiere Pro
Chuar Yapchong replied 9 years, 9 months ago 7 Members · 17 Replies
Ivan Myles
May 15, 2013 at 2:07 am[Ivan Myles] “default set to 6000 mbps”
Sorry for the typo. Should be 6000 kbps.
Abel Fernandez
May 3, 2014 at 2:30 pmI have the same issue, but if I just unlink it and set the new size to 1280×720 the video gets distorted. Thanks for any help with this issue
Abel Fernandez
May 3, 2014 at 2:32 pmHello Sean, I have te same issue. How did you exported to Quick Time 1280×720?
Ivan Myles
May 3, 2014 at 7:48 pm[Abel Fernandez] “I have the same issue, but if I just unlink it and set the new size to 1280×720 the video gets distorted.”
Check the Aspect setting. Otherwise, please provide more information regarding the observed distortion. A screen capture would be helpful.
Abel Fernandez
May 4, 2014 at 1:07 pmThank you for your prompt reply. The issue I have is that I shot the sequence in AVCHD and when I export it to H.264 at any frame rate (1280×720 for instance) it comes out fine. But the client wants it in .mov at 1280×720. When I choose to export it as a quick time file it changes automatically to 720×480. If I change that, say the width to 1280, it chamges the hight to 835 and if I change the hight to 720 it changes the with to 1820. Unless I unlink it. But when I unlink it the aspect ratio changes and I get an enlarged image.
Sean Winn
May 5, 2014 at 4:51 pmHi Abel,
Go in to the export dialogue box, choose Quicktime, then under presets, choose HD 720p. That will give you a 1280×720 quicktime file. Does that help?
