Activity › Forums › Adobe Premiere Pro › exporting a frame on CS4
  • exporting a frame on CS4
    Posted by Ron Weber on June 10, 2009 at 7:37 pm
    I just started using the new version. The previous version gave you the option to export a selected frame. I can’t find that option with this version. I need to export a selected frame to be edited in Photoshop. Any suggestions?
    Kris Strobeck replied 11 years ago 4 Members · 3 Replies
  • Ann Bens
    June 10, 2009 at 7:51 pm
    Update CS4 to 4.1. This update wil give you a still directly to hard drive. Look under Export/Media, then in the export settings under format dropdown menu you select your type of still.
  • Havi Ibrahim
    April 29, 2010 at 12:06 am
    You can use a single frame from your footage in premier -pro cs4 Easley, just cut the both side of the frame you want with Razor tool then unlink the video with the sound, then just select the video only right click on the video and then go to ( speed/duration) and then change the speed from 100 to only (1) and it will work just fine, ( make sure that the frame you select it NOT out of focus or blare.)
  • Kris Strobeck
    September 15, 2015 at 6:20 pm
    Figured this out… on CC. You just have to go to the keyframe icon in the track and select “Clip Keyframes.” Took me a while to figure this out! Goodness, very simple.
