Activity Forums Apple Final Cut Pro Legacy Exporting a FCP file directly to Compressor
  • Exporting a FCP file directly to Compressor
    Posted by Samuel Boulton on September 30, 2009 at 5:20 pm
    Hello,
    After completing a project with added DVD Studio Pro markers, I usually export the project to a QT movie. Then I use Compressor to encode the QT file. Once encoded, I import to DVD Studio Pro, add a menu, and then burn to a DVD.
    Will I compromise the quality of the final output, if I export directly from FCP to Compressor, and skip rendering to a QT movie?
    Thank you,
    Sam Boulton
    boultonmedia@gmail.com
    Samuel Boulton replied 16 years, 11 months ago 2 Members · 2 Replies
  • Rafael Amador
    September 30, 2009 at 5:28 pm
    [Samuel Boulton] “Will I compromise the quality of the final output, if I export directly from FCP to Compressor, and skip rendering to a QT movie? “
    Not at all, but the rendering time may increase.
    If you, as I guess, makes a Double Pass compression, everything is rendered twice, even if the sequence have been fully rendered.
    rafael
    http://www.nagavideo.com
  • Samuel Boulton
    September 30, 2009 at 5:38 pm
    Rafael,
    Thank you, you just saved me some time to enjoy my life.
    Sam B.
