Activity Forums Adobe Premiere Pro Exporting a FCP 7 XML to Premiere Pro – CS6
  • Exporting a FCP 7 XML to Premiere Pro – CS6
    Posted by Jason Pollard on February 1, 2013 at 7:53 pm
    Im working on a hour documentary and now am giving to a sound mixer for audio work. I cut the film on FCP 7 and need to get the sequence to the sound mixer whos working on Premiere Pro CS6 on a PC.
    I created a new project in FCP with only the final sequence in it and than using media manager I copied the media from the sequence to a separate drive. I then exported an XML file for use with Premiere.
    For some reason, when the mixer opens the XML in Premiere a lot of the clips reference wrong in/out points and some clips reference time code which does not exist in the original source clips.
    Has anyone heard of or encountered a problem like this with Premiere before?
    Jason Pollard
    Jason Pollard replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
