Activity Forums Apple Final Cut Pro Legacy exporting a 30 sec quicktime movie in FCP on a G5 to run smoothly on my G3 (help)
  • exporting a 30 sec quicktime movie in FCP on a G5 to run smoothly on my G3 (help)
    Posted by Grant Cowling on May 15, 2005 at 5:33 am
    Hey there,
    I was hoping someone or anyone could help me. I have just finished a 30sec film (tv ad) on my G5
    using final cut pro 4.1 and have saved in a quicktime.mov format. I burnt it to a disc so i can play the
    quicktime movie on my G3 800 mhz Power PC. Problem the clip wont run right, it skips, freezes, plays
    just the audio, skips to end etc. I was told to save it as soreson 3 or jpeg, kinda worked but still the
    same problem. Im new to final cut pro, but i think im doing pretty good. This problem is really
    pissing me off. As i’ve tried to save it in so many different file types, i’m starting to loose hair here.
    Any help would be like finding heaven….
    Kind regards Grant
    Grant Cowling replied 21 years, 3 months ago 2 Members · 2 Replies
  • Bobby Walker ii
    May 15, 2005 at 2:51 pm
    Are you playing it from the CD or copying the movie to the HD first? It should play fine on your HD (if not pump up the RAM). If its from the CD I’d check to see if the CD player is up to scratch, i.e. does it playback at only 8x?
    hth-
    bobby walker ii
    broadcast video COW
    G5 2.5GHZ DP,2.5 RAM, AJA IO LA, Medea G-Raid,FCP HD
  • Grant Cowling
    May 16, 2005 at 12:13 am
    Thanx for the tip. I was playing it from the cd, im sure its 8x. I’ll have to check again,
    well i’m going to give it all a try now…
