Activity Forums Apple Final Cut Pro Legacy Exporting a 29.97 QT movie from a 23.98 Timeline
  • Exporting a 29.97 QT movie from a 23.98 Timeline
    Posted by Brent Streeper on February 18, 2006 at 6:40 pm
    Hello,
    Just wondering if this is even possible. I have a 17 minute program on a 23.98 timeline that I would like to export as a 29.97 QuickTime.
    In the Export>QuickTime Movie window, I changed the setting from “Current” (1080psf 23.98 DVCPro HD) to 1080i 29.97 DVCPro HD. Everything seemed to go smoothly, but when I brought the exported QT movie into a 29.97 timeline, I had a clip that was only 13 minutes long instead of 17 minutes. The speed was right, it hadn’t been sped up at all. The export had just stopped 13 minutes into the process. But I got thinking and did some math and discovered that 13 minutes is about 80% of 17 minutes. 23.98 is about 80% of 29.97.
    Any ideas?
    Brent
    Graeme Nattress replied 20 years, 6 months ago 3 Members · 2 Replies
  • Miklos Philips
    February 18, 2006 at 8:21 pm
    When I had to do this – from a 16×9 / 23.98 FPS DVCPRO 50 timeline to a DV/ QT export at 29.97 I would just create another sequence with “DV at 29.97 FPS” settings and nest my final edit into that sequence. It would render out fine and would nicely letterbox the 16×9 into the 4:3 DV output. This would allow me to make a DV copy at 29.97 FPS.
    Point Zero Pictures
    <https://www.pointzeropictures.com>
  • Graeme Nattress
    February 19, 2006 at 1:01 am
    but correct 3:2 pulldown doesn’t get added via this method.
    If you need to add 3:2 as a render to convert 23.98fps to 29.97fps, use can use my G Film Converter plugin in Standards Conversion: https://www.nattress.com/Products/standardsconversion/GFilmConvert.htm
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
