Activity Forums Adobe Premiere Pro Exporting a 1290×1080 still
  • Exporting a 1290×1080 still
    Posted by Lori Savitch on May 11, 2011 at 7:14 pm
    I’m trying to export screen shots from some video I shot (1280 x 1080 (1.5) DVCProHD) using PPr cs5. Following the protocol, the exported JPEGS are “shmooshed” ala 4.3. I tried importing the “shmooshed” JPEG to Encore and changing it there, but no luck.
    Is there any setting I can change to get a JPEG screen shot with the same aspect ratio as the source video? If not — and if the solution is to use Photoshop – please tell me how, as I’m not very skilled with Photoshop.
    Thanks so much!
    -Lori
    Lori Savitch replied 15 years, 3 months ago 3 Members · 4 Replies
  • Jeff Pulera
    May 11, 2011 at 8:33 pm
    Hi Lori,
    Import still into Photoshop and use Image > Image Size to resize to 1920×1080, with “constrain” box UNchecked. This will give you an image that looks correct at 1920×1080 using 1.0 square pixel aspect ratio.
    I have to do this all the time with HDV grabs, which are 1440×1080 (1.333) and it works great.
    For grabs from interlaced video, you might need to use Filter > Deinterlace if there is motion artifacting. If so, do this before the resize.
    Jeff Pulera
    Safe Harbor Computers
  • Lori Savitch
    May 11, 2011 at 8:55 pm
    Oh, Jeff, thanks so much! I’ll do it tomorrow! And thank you for responding so quickly. You guys are just amazing. Thanks again!
    -Lori
  • Scott Roberts
    May 12, 2011 at 5:08 am
    Crop your timeline down to that one frame and export a Targa sequence.
    https://www.graphicsdump.com
  • Lori Savitch
    May 12, 2011 at 2:12 pm
    Thank you Scott. I’ll try that too.
    Many thanks,
    Lori
