Activity › Forums › Apple Final Cut Pro Legacy › Exporting 5.1 from FCP to compressor, Please Help
  • Exporting 5.1 from FCP to compressor, Please Help
    Posted by Vladislav on May 17, 2006 at 11:18 pm
    We had audio done in 5.1 mixing house, then brought files into FCP, tweaked some stuff, and now trying to export from FCP to compressor for audio encode. What is the best way?
    Here is our problem.
    I exported one file at the time from FCP naming them Left, Right, Center and so on to AIFF, then imported those files to Compressors Surround Sound Group after encode I dropped that file in DSP4. Everything worked good so far. Now, when I listen to this DVD, 5.1 mix sounds different. I did another test, put the raw files we got from our 5.1 guy into compressor, encoded went to DVD, works great. So seems like the problem in FCP export
    So what’s the best way to export from FCP to Compressor and preserve the 5.1 Mix correctly?
    Thank you
    Vlad
    Vladislav replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
