Activity Forums Zaxwerks Exporting 3D with transparent background
  • Exporting 3D with transparent background
    Posted by Petegeo on January 5, 2006 at 7:52 pm
    All,
    First, great tutorials and threads! I’m new to Invigorator and fairly new to AE but have already accomplished some great effects. This is a testament to create info on sites like this.
    I created a letter that rotates on it’s Y axis and want to use it in a lower third ID built in Motion. I’ve read the threads here and searched the web for an answer on both Invigorator and AE and am still confused. How can I render the spinning E with a transparent background so that I can place over footage?
    I have come very close using keying, trying both blue and green, but get some artifacts around the letter.
    Thanks in advance for the advice!
    Pete
    Petegeo replied 20 years, 8 months ago 2 Members · 2 Replies
  • John Dickinson
    January 5, 2006 at 10:25 pm
    Hi Pete,
    You need to render the layer out with an alpha channel. In the Render Queue you’ll see a section called OUTPUT MODULE. Under CHANNELS choose RGB + ALPHA and the DEPTH will change to MILLIONS OF COLORS+
    From the COLOR popup I recommend you choose STRAIGHT not PREMULTIPLIED. Keep in mind that you first will need to choose an output format in FORMAT OPTIONS that supports alpha channels; for example the Quicktime ANIMATION codec or perhaps a TGA sequence (32 bit option). Let us know if you need more assistance.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Petegeo
    January 5, 2006 at 11:31 pm
    Thanks JD! Worked like a charm.
