Activity Forums Apple Final Cut Pro Legacy Exporting 16:9?
  • Exporting 16:9?
    Posted by Tim Clancy on January 25, 2010 at 5:00 pm
    This is probably a pretty bushleague question but I’ve got to cut what amounts to a slideshow in FCP at 16:9.
    In sequence settings I used a 720×480 frame size but clicked on the anamorphic 16:9 option when cutting. In Final Cut it’s 16:9 but upon exporting it’s back to 4:3–I’m sure it’s a very simple reason why but what gives?
    Shane Ross replied 16 years, 8 months ago 2 Members · 3 Replies
  • Shane Ross
    January 25, 2010 at 5:11 pm
    The footage is 4:3 anamorphic. FCP stretches out the image so you can see it properly. QT often does not. You’ll need to export it with 16:9 ratio numbers (640×360 for example) if you want to see it FULL 16:9.
    What are you trying to export it for?
    Shane
  • Tim Clancy
    January 25, 2010 at 5:31 pm
    Ahh that makes sense. The client wants it for the web but with the photos at full resolution and at 16:9 for youtube so I was planning on not compressing it at all.
    Do you think I need to drop everything into a 640 x 360 sequence to make it fly?
  • Shane Ross
    January 25, 2010 at 5:40 pm
    Photos at “full resolution” are pretty poor when it comes to DV. 720×480 (well, a bit wider with anamorphic), and 72dpi. This is something you’d adjust in Photoshop.
    For YouTube, you export at whatever resolution you want it to play there. Just do the math and make it a multiple of 16:9.
    [Tim Clancy] “Do you think I need to drop everything into a 640 x 360 sequence to make it fly?”
    No…that is the WRONG thing to do. You work in your native resolution, and then export to the format you need when done.
    Shane
