Activity Forums Apple Final Cut Pro Legacy EXPORTING 16:9 STILL IMAGE
  • EXPORTING 16:9 STILL IMAGE
    Posted by James Simpson on October 18, 2005 at 1:11 pm
    Hi everyone,
    I can’t work out how to export a 16:9 still image from Final Cut Pro5 into Photoshop. It appears to export as a 4:3 image.
    Checked manual and previous post here, but no answers.
    What stupid mistake am I making?
    Thank you very much.
    Jim
    James Simpson replied 20 years, 11 months ago 3 Members · 4 Replies
  • Kevin Monahan
    October 18, 2005 at 7:35 pm
    You probably are not understanding how anamorphic widescreen works.
    If the exported still image is distorted or “stretched up”, yet still displaying a 720 x 480 frame, that’s just what a 16:9 anamorphic frame looks like. Anamorphic 16:9 is distorted on the fly to display in widescreen format, as I said, it’s actual frame size is 720 x 480. This is a common misunderstanding.
    You may want to read my article:
    https://www.kenstone.net/fcp_homepage/understanding_16_9.html
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Jeremy Doyle
    October 18, 2005 at 7:58 pm
    When you open it in photoshop go under image>pixel aspect ratio>d1 dv ntsc widescreen (1.2) and it should look normal.
  • Kevin Monahan
    October 18, 2005 at 8:11 pm
    Nice tip.
    But sure, It will “look” normal if you do that, but it is a trick in PS. The actual frame is distorted. It’s good to realize what is really going on under the hood. 😉
    Kevin Monahan
    fcpworld.com
  • James Simpson
    October 18, 2005 at 10:36 pm
    Thank you Kevin and Jeremy, it’s very much appreciated.
