Activity Forums Apple Final Cut Pro Legacy Exporting 16:9 sequence as self-contained movie
  • Tom Wolsky
    March 23, 2009 at 11:25 am
    You mean it doesn’t look squeezed; the images don’t appear tall and thin?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Niklas Wikman
    March 23, 2009 at 12:18 pm
    It sets the blank sequence to non-anamorphic and if I look at the clip properties, Anamorphic is NOT ticked.
    Sure, I could put the clip to the timeline and then set the timeline to Anamorphic, but would that really put the file onto DV tape as Anamorphic/16:9 ?
  • Tom Wolsky
    March 23, 2009 at 12:26 pm
    It sounds as if the wrong settings were used to capture the material. Is it anamorphic? If it is the check box should be set for the clips. Select all the clips and right-click in the anamorphic column. Make a new sequence setting that’s DV anamorphic and make a new sequence.
    All the best,
    Tom
