Exporting 16:9 ratio from Premiere Pro always warped in Quicktime and VLC
Although I have a little experience with Final Cut, I am new to Adobe’s Premiere Pro. Recently I finished my first project with PPro and have been trying to figure out the exporting panel and how to make it do what I need it to.
At present my (so far) unsolvable problem is that no matter which way I try to export my sequence, which is in a 16:9 ratio, whenever I open the resulting video in VLC or an older version of Quicktime (i.e QT7 or before) the image becomes vertically stretched!!!!!
The most frustrating part is that I can fiddle with the measurements until visually it fits these two players properly, but then it is stretched horizontally when I open it in QT X !?!? What kind of _____ ? Anyway…
The only other thing I can think to do is export an uncompressed version of the timeline, throw it in final cut, (hope that no confounding hick-ups pop out the wood work), and then re-export/encode through Final Cut, which I can only hope and assume will work like it has all the previous times I have used it.
If anyone has had this problem or knows how to solve it and can point me in the right direction, I will be forever thankful.
