Activity › Forums › Adobe Premiere Pro › exporting
  • exporting
    Posted by Ben Goodman on February 21, 2020 at 8:16 am
    Does anyone know if there is such a possibility of exporting one video file with different bitrate values inside it?
    For example, If I export a 3-hour video, of which two hours are lecture and one hour of a show, the lecture is not important to me to be in a high quality,
    but the show is important.
    Is there any software capable of doing this?
    ultimstly I’m asking if there is a way to control the VBR myself of how much bitrate to give to each frame over time.
    (So I can give the lectures low bitrate and the show- a high bitrate)
    Of course – all this is because I’m limited by the weight of the final file.
    Thanks a lot,
    Ben
    Shane Ross replied 6 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    February 21, 2020 at 8:33 pm
    No, sorry, you cannot have two data rates inside the same file. I mean, it can be variable, but that means that it just hovers near a set data rate, going slightly up or down as it plays. But no, you can’t have a really high one in one area, and then really low in another.
    Shane
    Little Frog Post
