Activity › Forums › Apple Final Cut Pro Legacy › Exporting 100 min FCP Timeline 720p footage shot with HVX200: What is my best option?
Sam Tollitt replied 17 years, 2 months ago 7 Members · 24 Replies
Sam Tollitt
October 2, 2008 at 1:14 pmexport a native Quicktime movie (self contained to be safe) from FCP and play direct from quicktime in full screen.
You don’t need another drive with FW800 or eSATA as the data rate for DVCPRO HD 720 will be no problem for the internal drive on any apple laptop made in the last 5 or so years!
You will need to change the full screen options in the quicktime preferences as it defaults too playing in the on with the finder controls.
If the projector is 1080 just for simplicity I would do the scaling in the mac (might not be the best but without a doubt it will defiantly look good) the mac will detect settings for the projector via the DVI connection, this is all available in – system preferences>displays if your having trouble viewing the projector output the settings might not be correct if so hit > gather windows so you can alter the settings from your normal/finder screen here you should be able to select something along the lines of “1920×1080 – 25Hz” this will work fine and look great, I’m sure 🙂As for the audio – simply feed a mini jack from you macs output too the amplifier, no point in trying to do something “clever” as this will give you a crisp stereo output for a viewing, which is all you require, right?
Hope all goes well
Sam Tollitt
sammy.cutcopy@gmail.com -
Matt Ramphal
October 2, 2008 at 5:30 pmThanks for all the solid advice everyone.
I will test out a few of these methods in the next week, and if it helps, I’ll report back on how thats goes.
Michael Dibiasio
November 12, 2008 at 9:57 pmHi Matt,
How did this turn out for you? Did you end up playing the Quicktime Movie through your computer?
I find myself in the same boat and would greatly appreciate any advice (from anyone)?
Only differences:
– Intel Dual Core Macbook Pro
– 45 min timelineHere are the specs for the projector, for anyone who knows about these things:
https://www.optomausa.com/Product_detail.asp?product_id=5
Michael
Sam Tollitt
July 15, 2009 at 5:49 pmsame as my last post!
1 thing i did not mention…
open the QT movie in question hit ‘apple & j’ and tick the high quality box! ( & de-interlace if your footage is interlaced)
all the best
