Activity › Forums › Apple Final Cut Pro Legacy › exported wav out synch
  • exported wav out synch
    Posted by Meenakshi Nangare on November 11, 2011 at 12:41 pm
    hi
    the film im working on is shot on 5D and 23.98fps and audio is on 25 hence it was out of sync.
    so i manually synch the audio….but when i export the wav of synced audio and slap it……it goes out of sync again….
    i tried exporting AIFF as well still it goes out of sync.
    how do i solve this problem??????
    HEPL!!!!!!!!
    meenakshi
    Jerry Hofmann replied 14 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 11, 2011 at 2:36 pm
    Did you transcode the 5D footage to ProRes first? That’s a must.
    Also might consider transcoding the audio to be 23.98 to avoid the syncing issue in the first place.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
