Activity › Forums › Adobe After Effects › Exported video Tiny
  • Exported video Tiny
    Posted by Conan Stott on May 2, 2008 at 1:48 am
    Hi… Im having problems when working on a clip in AE and exporting to bring into final cut.
    I export the clip with the composition settings the same as my final cut project. I choose uncompressed 10bit quicktime, but when I import it into final cut it appears tiny in the viewer. The viewer is set to 100% but the clip is about 50% the size of the original that I imported into after effects.
    What could be causing this?
    Thanks in advance
    Conan
    Michael Duff replied 18 years, 5 months ago 2 Members · 1 Reply
  • Michael Duff
    May 2, 2008 at 2:26 am
    firstly, are you actually exporting using File->Export? If so, DON’T! … you should be using the render queue to output your movies … go to Composition->Add to Render Queue
    then there are a number of settings you can choose from … if your composition settings are a broadcast preset (PAL, NTSC whatever) then you shouldn’t need to change the size of the output …
    have a go at this, then if you have any more specific questions about the render queue then feel free to ask 🙂
    good luck
    Michael Duff –
    Bearcage Productions, Australia
    http://www.bearcage.com.au
