exported video file glitch
I was recently working on a video in final cut and had a couple simple non-video elements in the timeline in addition to the video. a freeze frame, png file, slug, and a couple text files. everything looked swimmingly in the canvas when i played it back so, i decided to export it. i used the default settings on the quicktime file export setting.
when i played the video file back in quicktime, there were major image glitches on the specific sections with those non-video elements. the glitches would also throw the audio out of sync.i tried encoding the video over again in a h.264 codec in adobe media encoder and that didn’t fix anything.
this is the first time this has happened but certainly not the first time i have tried to use the same elements in a video.
any expert advice on things to try would be greatly appreciated.
thanks!
kyle.m
