Activity › Forums › Apple Final Cut Pro Legacy › Exported movie longer than FCP sequence!
Posted by Jeremy Levine on May 18, 2010 at 5:20 pmHey all,
I’m sure I’m missing something simple but this one has me stumped. My exported film is 10 minutes longer than my sequence.
I’m editing in Final Cut Pro 6.0.6
I shot on an HPX-170 at 720pn (23.98)
My sequence is set to DVCPRO HD -720p24 (23.98)
Sequence starts at TC: 01:00:00:00 and ends at 01:40:06:29
Export Quicktime Movie at current settings or at DVCPRO HD – 720p24 results in the same longer clip
Exported clip is 50:11What am I missing here? Thanks!
JeremyBernat Aragones replied 16 years, 4 months ago 9 Members · 13 Replies -
Jerry Hofmann
May 18, 2010 at 5:32 pmCould it be that you’ve set an out point later than at the end of the sequence?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Mark Maness
May 18, 2010 at 5:46 pmHave you checked to see if there some piece of media that got shoved down your timeline about ten minutes after you program?
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Steve Eisen
May 18, 2010 at 6:03 pmShift Z will allow you to see the entire timeline.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group -
Jeremy Levine
May 18, 2010 at 6:13 pmThanks for everyone’s response. There is no extra media at the end, the out point is set at the right place and I checked that every clip and sequence is 23.98 (I went into sequence settings for each sequence and I checked the clips in the browser). Is there anywhere else I should look?
Out of curiosity, I tried exporting the first 10 seconds of the sequence and it came out to be 12 seconds long!
For reference, I had copied and pasted media from other sequences into this master sequence, but it’s all the same footage and set at the same sequence settings. Totally confused here.
Jeremy Levine
May 18, 2010 at 6:26 pmAnother update, I tried a rough timing test, using a stop watch against playing my timeline back. After 10 seconds on my stop watch, the sequence was only at 1:00:08:00. What could cause this?
Adam Smith
May 18, 2010 at 7:44 pmI had that gravity well thing once before… tough to troubleshoot unless you can move the whole edit rig. Test the other options first.
Video Photographer / Avid & Final Cut Editor -
Jeremy Levine
May 18, 2010 at 10:32 pmThanks to all. Yes, must have been space-time continuum. I trashed preferences, no effect. Then I created a new sequence, copied and pasted from the old sequence, and the new sequence is now 50 minutes, the same time as the export. Still confused, but problem solved.
John Pale
May 18, 2010 at 10:35 pmDoes the timecode rate match the acutal frame rate? Could the timecode rate be 60 ?
Randy Lee
May 19, 2010 at 9:51 pmOpen up your sequence and hit cmd-0 (that is a zero). That’ll give you everything you need to know. Otherwise it’s in the browser, for both the individual clips and the timelines, if you just scroll over to be able to see it.
