Activity Forums Apple Final Cut Pro Legacy exported movie juddering with smoothcam filter
  • exported movie juddering with smoothcam filter
    Posted by Oli Mival on July 7, 2009 at 1:18 pm
    Hi All,
    I’ve filmed a walkthrough of a house for someone using the Sony A1 shooting 1080i50 HDV on a glidecam. I then used the smoothcam filter to make it as steady as possible which has worked really well. However, when I export it out as an H.264 720p movie it has a strange juddering effect on any pans which is extremely off putting. You can see the movie here (https://www.vimeo.com/5181061). I realise this is a Vimeo flash encoding but it is a very accurate representation of the problem in the Quicktime movie. The same effect appears when exporting out a default 1080i HDV and even an animation codec version, yet it doesn’t appear on the Canvas playback which is smooth as silk. The final output of this will be web based probably as a flash movie but QT would do. Any ideas would be really appreciated!
    Oli
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Dave Wilkinson replied 17 years ago 4 Members · 3 Replies
  • Jason Diebler
    July 7, 2009 at 8:13 pm
    The footage looks really good. Try using the Stabilize Behavior in Motion, you may get a better result… just make sure your export settings are set to Render Best/Full Res or that your FCP sequence settings (if you roundtrip) are set to Video Processing/Render Quality = Best.
    “The deepest blues are black” – Foo Fighters
    (this doesn’t help me when I’m chroma keying!)
  • Michael Gissing
    July 7, 2009 at 11:05 pm
    This sounds like a recurring issue. There were posts not so long ago reporting this. My suggestion at the time was to export the smoothcam shots as quicktimes (in the same codec) and overlay them in the timeline. I don’t recall any feedback so perhaps a search might find the original thread and it may contain the confirmed solution.
    Do us a favour and report back if you fix it and how. It means the next searcher will find a solution.
  • Dave Wilkinson
    August 29, 2009 at 6:15 pm
    Oli, did you ever solve this judder problem?
    I’m, getting exactly what you describe, and have tried various fixes.
    Do you have a fix yet?
    Dave
