Activity › Forums › Adobe Premiere Pro › export xml with nested sequences merged
  • export xml with nested sequences merged
    Posted by Jacek Ryś on September 4, 2015 at 10:28 am
    is there some way to export project / timeline (xml,edl,…) without hierarchical sequence structure i mean, as flat one sequence.
    why? what for?
    It is easier to copy-pase footage into another larger-size sequence then, because larger size footage expands easily into larger sequence size, but nested sequences cause cropping.. does premiere support some scripting? if not, there is always a way to process directly xml file using php?
    Jacek Ryś replied 11 years ago 1 Member · 0 Replies
  • 0 Replies
