Activity Forums Adobe Premiere Pro Export XML from premiere to final cut removes link between video and audio
  • Export XML from premiere to final cut removes link between video and audio
    Posted by Leevun Vanhove on July 2, 2015 at 9:44 am
    Hi Everybody,
    I’m currently working on a project together with a friend of mine. He is working in Final Cut, and I’m working in adube premiere pro CS 5.5.
    We work on the same sources, he exports an xml for me, which I can import in premiere. Until then, there isn’t a problem.
    I work on the project, and export a XML myself to send it to him. Everything seems to be ok, but when he opens the project. All the links are gone between the video and the audio?
    Somebody ran into this problem too?
    Thank you,
    Leevun Vanhove replied 9 years, 8 months ago 1 Member · 2 Replies
  • Leevun Vanhove
    December 8, 2016 at 2:30 pm
    Hello Everybody,
    Now, a year later, I’m again working on a project, and the problem keeps reoccurring even with premiere CS6 and premiere CC.
    Does anybody ran into this problem too?
    Thank you,
    Lieven
  • Leevun Vanhove
    December 8, 2016 at 2:32 pm
    A little bit more information: my colleague is working with final cut 7.
    Also, after I export the XML from premiere, and re-import it in premiere, the link is also gone in premiere.
    It seems the link gets lost while exporting the XML.
    Thank you,
    Lieven
