Activity Forums Adobe Premiere Pro Export without rendering first?
  • Export without rendering first?
    Posted by Mike Tomei on September 28, 2010 at 2:00 pm
    Hello all,
    I’ve searched the forums, but found mixed opinions on this. I’m working on a project in Premiere CS5 that contains mixed formats, so I have some render lines appearing. (AVC-INTRA and some standard def DVD files inside a DVCPRO HD sequence) I can edit the project just fine without rendering. I’m wondering if I need to render before I export to Adobe Media Encoder, or will AME render as it exports?
    I’m also curious as to the workflow aspect of this. For those of you who have a heavy workflow, do you render first then export to AME, or not render first?
    Thanks.
    Mike Tomei
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
    Adobe Production Premium CS5
    Ann Bens replied 15 years, 11 months ago 2 Members · 1 Reply
  • Ann Bens
    September 28, 2010 at 9:26 pm
    Whatever is on your timeline export with Max Render Quality (just in case) and do not use the Preview files. MPE will render new files for you. This will give a better result.
