Activity › Forums › DaVinci Resolve › Export with 44.1k audio
  • Export with 44.1k audio
    Posted by Chris Tompkins on October 12, 2020 at 9:35 pm
    I have a 1080/30p/48k project, client needs a mp4 file with 44.1k audio for their playback.
    Resolve only will export file with 48k.
    I created a new project to try and get a 44.1k project but had no luck.
    One work around, i created a DnX hi-res master, dropped that in Adobe Media Encoder, made a 44.1 file, however, the video is washed out some.
    Anyone have advise on how to export from resolve making the audio, 44.1k audio?
    Thanks.
    Glenn Sakatch replied 5 years, 11 months ago 4 Members · 5 Replies
  • Eric Santiago
    October 13, 2020 at 3:02 am
    What’s the target format?
  • Chris Tompkins
    October 13, 2020 at 3:18 am
    mp4, i ran it thru handbrake to get to 44.1k
  • Michael Gissing
    October 13, 2020 at 5:06 am
    Did you go to the original timeline settings and change it to custom settings and then tried to change the sample rate? I can’t check now as I’m rendering out a doco but you should be able to do that and Resolve should do a sample rate convert. Alternative would be to drop your DNx render file into a timeline that was set to 44.1 first and not changing settings when prompted by the mismatch.
  • Chris Tompkins
    October 13, 2020 at 1:09 pm
    I can’t see anywhere to change timeline settings, or custom settings, i have tried creating a new project, yes. But again, cannot find an option for audio settings.
    Thank you for your input.
  • Glenn Sakatch
    October 17, 2020 at 3:19 pm
    in the early days for Blackmagic Resolve, it couldn’t read 44k audio files, so i wouldn’t be shocked to hear it wont export them. 48 is not typical for video anymore.
