Activity Forums Apple Final Cut Pro Export Video with Alpha Channel in FCPX?
  • Export Video with Alpha Channel in FCPX?
    Posted by Oscar Brightman on May 26, 2016 at 6:40 pm
    Hello, I have a interview on greenscreen and I keyed out the green. Client is requesting 32 bit movie with alpha channel. Is this possible in FCPX? How do I export movie with Alpha channel and also how to I export in 32 bit?
    Many thanks
    Oscar Brightman replied 10 years, 3 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    May 27, 2016 at 2:01 am
    32 bit most likely means 4:4:4:(4)
    4×8 is “32bit”. The forth four is the alpha channel.
    Set your project render settings to ProRes 444 in the Project Settings (command-j) and share a master file with “same as source” settings in the codec.
  • Oscar Brightman
    May 27, 2016 at 4:25 am
    Worked like a charm. Thank you!
