Activity › Forums › Apple Final Cut Pro Legacy › Export via QT Conversion to WMV exports only first 29 seconds(?)
  • Export via QT Conversion to WMV exports only first 29 seconds(?)
    Posted by Maxwell Federman on February 7, 2011 at 5:53 pm
    Hello–
    I made the mistake of telling a client it would not be a problem converting his material to WMV.
    I captured his tapes using DV; and figured it would be no problem to export them using the Quicktime Conversion export dialog.
    I exported a short test file (8 seconds) and emailed it to a friend with a windows computer to test quality and compatibility.
    The test went fine, but now I am trying to export the full files and it is only exporting the first 29 seconds. Plus the quality appears to have taken a hit. I’m gonna keep trying to adjust these settings and maybe will see if MP4 files would be ok (?)
    Your advice is appreciated; thanks for reading this!
    Thomas Morter-laing replied 15 years, 7 months ago 2 Members · 1 Reply
  • Thomas Morter-laing
    February 7, 2011 at 7:36 pm
    If your client has QuickTime or can install it, do h264. Free and better 🙂
    Tom Morter-Laing
    Freelance Editor
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
