Activity Forums Apple Final Cut Pro Legacy Export via network, 2GB file
  • Export via network, 2GB file
    Posted by Pierre-luc Pare on August 8, 2007 at 3:01 pm
    Hey guys,
    I use to export from FCP via network to mac formatted HD plugged into a Windows computer using MacDrive. Most of the time it works great. But what I find annoying is that the exported quicktime file is always split into multiple 2GB files, instead of only one file as exported directly on Mac FW drives, why ?
    Also, sometimes, FCP gives me a “General error” when I export that way (Mac FW drive, Windows, network) but will be ok when exported on the Windows IDE NTFS drive.
    I know this more a OS than FCP question, but maybe someone has experienced this in the past.
    Pete
    Tom Brooks replied 19 years, 1 month ago 3 Members · 3 Replies
  • Walter Biscardi
    August 8, 2007 at 3:19 pm
    [Pierre-Luc] “But what I find annoying is that the exported quicktime file is always split into multiple 2GB files, instead of only one file as exported directly on Mac FW drives, why ?”
    Windows limit is 2GB files. There is a way to format the newer Windows OS to allow larger files sizes, but I honestly don’t know what that is.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Pierre-luc Pare
    August 8, 2007 at 5:31 pm
    Well, that’s something I was aware of, but I can copy a file as large as 60GB and more. I just can’t while exporting from FCP…
  • Tom Brooks
    August 9, 2007 at 10:54 am
    That sounds like a drive formatted FAT32. Are you sure the FW drive is formatted Mac HFS+?
