Activity Forums Adobe After Effects Export uncompressed footage from Premiere CS6 to be used in Resolve
  • Export uncompressed footage from Premiere CS6 to be used in Resolve
    Posted by David Garcia on August 10, 2012 at 3:08 pm
    I have some 5k footage that we are editing on a 1080p timeline in premiere. The reason we did it this way is to reframe the shots in post.
    We want to grade in Resolve LIte which can only do 1080p and not 5k. This means that we cant go via XML as Lite only accepts 1080p.
    Uncompressed YUV 422 seems good. Any thoughts?
    Thank you
    Angelo Lorenzo replied 14 years ago 4 Members · 3 Replies
  • Tudor “ted” jelescu
    August 10, 2012 at 6:11 pm
    422 means you loose color information- for best results use a 444 format.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Walter Soyka
    August 10, 2012 at 6:19 pm
    [Tudor "Ted" Jelescu] “422 means you loose color information- for best results use a 444 format.”
    Good call. I’d consider using a DPX sequence.
    Walter Soyka
  • Angelo Lorenzo
    August 10, 2012 at 6:22 pm
    A DPX sequence is way easier to deal with than an uncompressed video file. It will allow you to re-render and color portions without having to re-render the entire film.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
