Activity Forums Adobe After Effects Export to youtube
  • Export to youtube
    Posted by Jeroen Tiebout on October 16, 2011 at 6:54 pm
    Hello,
    I just made a vid, and wanna upload it to youtube, so as far as I know I have to click “export” than I can choose between:
    – adobe flash player
    – adobe flash professional
    – adobe premier pro project
    And I don’t know which to choose, and which one works..
    Tudor “ted” jelescu replied 14 years, 10 months ago 3 Members · 2 Replies
  • Marjolein Van diejen
    October 16, 2011 at 7:12 pm
    In After Effects, it is usually best to use the “Render” option. Go to Composition in the top bar, then select “Add To Render Queue”. The composition/video will then be added to this queue, where you can change the setting for the final video. When you have entered the settings you’d like, click on “Render”.
  • Tudor “ted” jelescu
    October 17, 2011 at 9:08 am
    To add to the previous post, although AE gives you various render options, it is best to use Adobe Media Encoder to compress/render for the web. Open your AE project in Adobe Media Encoder. This will give you a window where all your comps in that project will show up on the right (it may take a while to load them so be patient). Choose the comp you want to render and then choose one of the presets. For YouTube .flv/f4v should do the trick.
    Tudor “Ted” Jelescu
    Senior VFX Artist
