Export to Web settings
I have a movie that I want to put on my website for people to download over the web. I have done this loads of times before but normally I use Windows Movie Maker for this and have had great success with it and as a result I know the settings I want to use.
However, with this new project I needed to crop the actual size of video footage slightly (you could see the boom mic at the top of the screen – doh!) so had to use Premier. I would like to use Premier in the long run now but am having problems with the export process.
Basically I want to export it as a WMV file with a viewable size of 640 x 480 pixels with the final result being about 6Mb of file size for each minute of footage. I normally use 768Kbps with an Aspect Ratio of 4:3, 25 frames per second when I use Windows Movie Maker and it comes out fine.
However, in Premier Pro when I come to export it, it won’t let me do it at any other option other than 320×240 pixels.
Any advice?
Many thanks,
Charles Goodall
charles@a1itsolutions.com
