Activity Forums Apple Final Cut Pro Legacy Export to tape
  • Posted by Jared Hawco on October 15, 2008 at 7:02 pm
    How can I export raw footage(.mov) from FCP to a minidv tape using my DVX100B? I have tried a couple of methods but the screen on my camera just stays blue and flashes records when I press play on the timeline. Some instructions would help big time.
    Arnie Schlissel replied 17 years, 10 months ago 3 Members · 2 Replies
  • Shane Ross
    October 15, 2008 at 7:18 pm
    Shane’s Stock Answer #8: External Monitor Viewing
    If you are working with DV, this is simple. First connect your computer to a camera or deck via firewire, Then connect the camera/deck to your TV/Monitor via RCA or S-Video.
    Then start up your camera and tv, then open fcp.
    Go to the View Menu, choose > External video > all frames
    VIEW>Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    VIEW>Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section.
    If you are working with HDV footage, FCP 6 allows you to view this via firewire, but ONLY as downconverted DV. It won’t look the best, but you can see it. To do this,
    If you need to view any format other than DV at full resolution, then you need to look into capture cards. Several standard definition and high definition models are available from http://www.aja.com and http://www.decklink.com. With these options you’ll need a proper monitor to view full broadcast colors, but all models allow for realtime standard definition downconvert, allowing you to view HD on an SD monitor.
    The Matrox MXO is another option that is output only, but allows you to view your footage on an Apple Cinema Display at full broadcast quality.
    Shane
  • Arnie Schlissel
    October 15, 2008 at 7:25 pm
    [Jared Hawco] “Some instructions would help big time.”
    Your FCP manual explains how to lay off to tape using either “Print to Video” or “Edit to Tape”. Look up either one in the online help.
    The manual for the DVX will explain how to set it up to record over firewire.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
