Activity Forums Adobe Premiere Pro export to tape
  • export to tape
    Posted by Chris Balogh on July 8, 2009 at 1:16 pm
    For some reason my export to tape in unhighlighted where i CANNOT record to tape? Any suggestions? I have a set top dvcam that totally works and is plugged in…and even gives playback? Whats the deal?
    Jon Barrie replied 17 years, 1 month ago 2 Members · 1 Reply
  • Jon Barrie
    July 10, 2009 at 2:36 am
    Does it work with other projects? (recently successful exports)
    You could import the project into a Saved As copy of a project that works properly and then export it from there. The settings may be different, HDV settings may have crept in there with a HDV ingest at some point and the deck thinks it’s trying to be exported to as a HDV unit which will create a conflict and not work.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
