Activity Forums Adobe After Effects Export to Print Thread
  • Export to Print Thread
    Posted by Joeythedog on September 26, 2005 at 11:11 pm
    I precomped the layers that I wish to make a good quality 16×20 print of.
    I then increased the size of my composition to 7500×5400.
    Do I now rescale the image to be the size of the composition window?
    I then Rendered the frame as a tiff. It made a 148mb file. Then opened in Pshop and fine tuned. It was 72 dpi so I made it 360 dpi. My normal print resolution. And reduced the image size to appx 16×20. It looks real good on the monitor but I don’t know if this is the proper way to do this.
    Roland R. kahlenberg replied 20 years, 11 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 27, 2005 at 3:51 am
    You shouldn’t scale as this will introduce pixelation. Ideally, you would redo your comp in AE with larger footage. For vector images scaling should’nt be a problem, you can use Motionmath scripts, scalleall.mm or scaleby.mm to enlarge layers to fit the current comp size. For version 6.5, use the ScaleComp.jsx script.
    For raster images, it’ll give you an indication as to how large your source files need to be in order to maintain the original resolution. Then see how you can acquire the original with the new dimensions. For videos, there is really no way to have a higher resolution image. Your best bet is to use Photoshop’s Bi-linear or perhaps Nearest Neighbor (depending on image) to do the scaling. Then import the file into AE and replace the version that was scaled up by AE.
    Secondly, your calculations seem to be off: for a 16″x20″ output at 360 dpi, you’d need a comp size that’s 5760×7200 pixel compo size. What you did in PS is fine.
    HTH
    Roland Kahlenberg
    broadcastGEMscustomizable animated backdrops with Adobe After Effects project files
