Activity › Forums › Adobe Premiere Pro › Export to MPEG-2 render problem
  • Export to MPEG-2 render problem
    Posted by Zach Yomboro on January 5, 2010 at 5:04 pm
    I am trying to render to MPEG2 out of Premiere CS4 to send to TV stations, when I play back the rendered file in Windows Media Player, all I get is audio. I copied the exact render settings from Premiere Pro 2 which I never had a problem with. The render settings are as follows:
    Video:
    Codec: MainConcept MPEG Video
    Quality:5
    NTSC
    720×480
    29.97 non-drop
    Lower field first
    Standard 4:3
    Profile: 4:2:2
    Level: High
    Bitrate Settings:
    VBR 2 Pass
    18
    18
    18
    GOP settings:
    M: 3
    N: 15
    Closed gop every: 0
    Advanced Settings:
    Macroblock: 10
    VBV Buffer size:488
    Sensitivity
    No
    0xfff
    9 Bits
    yes
    no
    0
    0
    0
    Audio:
    MPEG
    MPEG-1, layer II audio
    Stereo
    16 bit
    48khz
    384
    psychoacoustic model 2
    No emphasis
    Off
    Off
    Off
    Off
    Multiplexer:
    MPEG2
    Constant
    0
    2048
    1
    0
    4
    Zach Yomboro replied 16 years, 8 months ago 2 Members · 4 Replies
  • Ann Bens
    January 6, 2010 at 11:52 am
    Lower the profile.
  • Zach Yomboro
    January 6, 2010 at 2:54 pm
    That’s the problem we need it to be 4:2:2 for the TV stations.
  • Ann Bens
    January 6, 2010 at 7:04 pm
    Try profile 422 and level Main
  • Zach Yomboro
    January 7, 2010 at 5:23 pm
    Lowering the level to main did not work either. Any other ideas?
