Activity › Forums › Apple Final Cut Pro Legacy › Export to iPhone
  • Export to iPhone
    Posted by Miodrag Ristic on July 7, 2010 at 2:13 pm
    I’ve been exporting for iPhone so far via Export to iPhone (m4v) automated setting and was happy with the quality,
    but movies look squeezed.
    What would be best way to achieve 16:9 ratio with maintaining quality?
    Anyone has any experience with this?
    Mio
    Jeremy Garchow replied 16 years, 2 months ago 3 Members · 15 Replies
  • 15 Replies
  • Stephen Smith
    July 7, 2010 at 2:38 pm
    I like to use Compressor. I has a great pre-set. Go to the Settings tab in the bottom left corner and open the Apple, Apple Devices folder. Choose H.264 for iPod video and iPhone 640×480. It works great. Best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Miodrag Ristic
    July 7, 2010 at 2:44 pm
    Thanks Stephen, but that’s still 4:3, I get that pretty good automatically out of FCP,
    but I’m looking for 16:9.
    I don’t want it to look squeezed, I’m talking about HD source (DVCPRO HD)
    BTW, good job with that Motion DVD.
    Mio
  • Stephen Smith
    July 7, 2010 at 3:54 pm
    Thanks Miodrag,
    This is a cool feature about Compressor. When you are in compressor and drag the preset to your video, Compressor realizes that your footage is HD and changes the aspect ratio to the preset. If you go into the Encoder window you will see that the Aspect Ratio is changed into 16×9 (360×360). It works great and looks great.
    Stephen Smith
  • Jeremy Garchow
    July 7, 2010 at 3:57 pm
    Duplicate the Compressor preset then you can choose the aspect ratio.
    Jeremy
  • Jeremy Garchow
    [Dave LaRonde] “Is the iPhone’s screen 4×3 or 16×9?”
    How about neither? 🙂
  • Jeremy Garchow
    July 7, 2010 at 4:10 pm
    [Dave LaRonde] “That’s what I get for being a Luddite, I guess…. “
    Nonsense! Having an iPhone does not make one a non-Luddite. Not having an iPhone does not make one a Luddite. 🙂
    iPhone 4 is 960×640 and below that is 480×320 (so 3:2).
    Jeremy
  • Miodrag Ristic
    July 7, 2010 at 9:34 pm
    Thanks Jeremy.
    Tried that but then when pressed Submit, I’m getting message: ” Cannot submit batch
    Unable to connect to background process.”
    I must have done something wrong when creating that custom setting for H.264 for iPod.
    Mio
  • Miodrag Ristic
    July 7, 2010 at 10:18 pm
    Tried deleting .plist files for Batch and Compressor and that Custom Preset is still there.
    Can’t Submit under any setting.
    I’m running Compressor 2 and FCP 5.1.4
    Probably didn’t like that Custom preset being created ??
    Searched on the web… apparently it’s a known issue and I have to reinstall Compressor and QMaster
    Anyone with a more “elegant” solution?
  • Jeremy Garchow
    July 7, 2010 at 11:24 pm
    [Miodrag Ristic] “Probably didn’t like that Custom preset being created ??
    Anyone with a more “elegant” solution?”
    It has nothing to do with the preset, it’s just that version of COmpressor went South. It used to happen to me, no matter what preset.
    Reinstalling is the only way to fix it, really.
    You can also try Compressor Repair, but not sure if it works with v2:
    https://www.digitalrebellion.com/compressor_repair.htm
    Jeremy
  • Stephen Smith
    July 8, 2010 at 12:12 am
    You don’t need a 16×9 and 4:3 iPhone preset. All you need is the default preset. If you drag a 4:3 clip into compressor and then apply the iPhone 640×480 preset it will make the Aspect Ratio 4:3 (640×480). If you drag an HD clip into compressor and then apply the iPhone 640×480 preset to it it will may the Aspect Ratio 16:9 (640 x 360). Compressor will do it all for you. I do this all the time with HD clips and the look fantastic.
    Stephen Smith
