Activity Forums Apple Final Cut Pro Legacy Export to H.264 – Jittery footage – Quicktime?
  • Export to H.264 – Jittery footage – Quicktime?
    Posted by Jimmy Hurlburt on March 16, 2010 at 6:28 pm
    Greetings,
    I have a HPX 500 camera using P2 cards. We have Mac OS X 10.5.8 Leopard. We use Dual Adapter for our input of our P2 footage. Recently we have run into a very frustrating problem. We just got done editing our footage and everything looked perfect and we were happy. Then we put the videos through compressor so that we could create a h.264 version for the client to look at it. When we viewed the video it looked very jittery and looked like it was doubling up on frames in some spots or like there were hits in the video. We also tried .mov, mpeg4 and .wmv and the same result. We have since then tried everything possible to trouble shoot and we have no idea what to do. The raw footage looks fantastic on a CRT monitor but on export we are still running into the same problems (jittery video – ect.) We have shot some extra footage as tests in different situations and we still are getting the same result. On the HPX 500 the footage looks good.
    Is it a quicktime problem? We’ve tried exporting via FCP as well and the same results.
    Any ideas on what you think we could try? Please help this is horrible and very time sensitive, we have shoots coming up and I don’t feel confident at all in anything right now.
    Also, this is happening on different MacBook Pros.
    Below is what our YouTube video looks like, PLEASE HELP……
    If you watch around the 51 second mark you should see the issue very noticeable.
    We are using:
    Mac OS X 10.6.8
    2.16 GHz Intel Core Duo
    2 GB 667 MHz DDR2 SDRAM
    Leopard
    FCP:
    Version 7.0.1
    Footage was shot in 1080i60
    29.97 fps
    Compressor DVCPRO HD 1080i60
    Sequence settings:
    Fame Size 1280 x 1080
    Aspect Ratio – HD (1280×1080) (16.9)
    Pixel Aspect Ratio – HD (1280ix1080)
    Field Dominance – Upper (Odd) – We changed this from Lower (Even) because it gave us the best result so far.
    Editing timebase – 29.97
    QT Video Settings:
    Compressor: DVCPRO HD 1080i60
    Quality: 100%
    YouTube file:
    https://www.youtube.com/watch?v=Gk9H6iBPNNQ
    Jim Carswell replied 16 years, 5 months ago 4 Members · 4 Replies
  • Bj Ahlen
    March 16, 2010 at 8:40 pm
    You are rendering to interlaced footage for display on a progressive computer screen, This can lead to many surprises.
    Try the “YouTube HQ 16:9” setting in Compressor, that may just fix the problem.
  • Jim Carswell
    March 16, 2010 at 9:16 pm
    1280×1080? Not familiar with that one. I’m familiar with 1920×1080, 1440×1080, 1280×720 but not what you listed. Could that be your issue as well?
    Jim
    Jim Carswell
    Spyhop Productions, Inc.
    Savannah, GA
    http://www.spyhopproductions.com
  • Arnie Schlissel
    March 16, 2010 at 10:55 pm
    DVCPro HD 60i is compressed at 1280×1080.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Jim Carswell
    March 16, 2010 at 11:15 pm
    Arnie,
    You’re right. My bad.
    Jim
    Jim Carswell
    Savannah, GA
