Activity › Forums › Adobe After Effects › export to flv
  • export to flv
    Posted by Stezza on November 9, 2007 at 4:59 pm
    Hi folks.
    I used to be able to export to flv from after effects 7 but now the option in the export menu is not there only swf and others.
    I have Flash CS3 installed also
    Any help
    thanks
    Chuck Obernesser replied 18 years, 10 months ago 3 Members · 2 Replies
  • Richard Harrington
    November 9, 2007 at 5:53 pm
    Use teh render queue and make sure you also installed the option FLV Converter on the Install Discs
  • Chuck Obernesser
    November 10, 2007 at 1:09 am
    One how can you tell if you installed FLV converter. And two do you need Flash itself so it will work. I have video’s I want to be flash and see it in AE, but I tried it and it didn’t seem to work.
    Chuck
