Activity › Forums › Adobe Premiere Pro › Export to DVD — Flickering Green lines
  • Export to DVD — Flickering Green lines
    Posted by Isaac Anderson on January 7, 2010 at 6:19 pm
    Has anyone had little green lines flicker at the bottom of their files when selecting the “MPEG2-DVD” option with Adobe Media Encoder? It’s a small flickering green line, that is only a few pixels thick, that occasionally flashes at the bottom of my mpeg encoded m2v video files.
    Field order, cropping, scaling, etc doesn’t help…nor does exporting from different file types to the MPEG2-DVD setting.
    I’m running CS4, and AME is exporting to DVD using MainConcept. It does the same thing in AE, Encore, and AME. Thanks!!!
    Isaac Anderson replied 16 years, 8 months ago 2 Members · 2 Replies
  • Jeff Brown
    January 7, 2010 at 7:20 pm
    Have you tried more than one playback method to check? (WinMedia player vs. set-top DVD player, QuickTime…)
    -Jeff
  • Isaac Anderson
    January 7, 2010 at 9:47 pm
    I have…same problem in various players, and the same problem on two different computers (encoding as well as playback 🙁
