Activity › Forums › Adobe Premiere Pro › Export to DVD – Encoding options
  • Export to DVD – Encoding options
    Posted by Raymond Tarry on April 21, 2005 at 12:54 am
    Hello – I burned an 11 minute scene to DVD this morning. I used the top most encoder preset:
    “NTSC DV 16×9 LOw Quality 3MB VBR 1 Pass” The result looks fine, but it’s a little small on the TV screen.
    Does anyone know the advantages of the other presets? Thanks Raymond
    Martin Tiller replied 21 years, 5 months ago 3 Members · 2 Replies
  • Mike Velte
    April 21, 2005 at 11:36 am
    A higher bitrate, like 7 mbps would make your footage look even finer and a preset with 4:3 aspect ratio will fill up the screen.
  • Martin Tiller
    April 21, 2005 at 2:35 pm
    To add on what Mike said, Premiere’s presets states High Quality and Low quality at the front of each description. Use one stated High Quality and compare the results.
    Good luck,
    Martin Tiller
    http://www.mctimages.com
