Activity Forums Apple Final Cut Pro Export to DVD
  • Export to DVD
    Posted by Matthew Celia on December 4, 2011 at 10:32 pm
    Burning a one-off DVD via FCPX and decided to speed things up to select background rendering “Use This Computer Plus”. The problem is that even though in Compressor I have specifically set it Not to Copy files, I found that the share monitor was copying the entire 90 minute cut to my internal hard drive (which wouldn’t have fit had I kept it going!)
    Any suggestions for how to turn that off, or how to set it for another drive? As lame as it is, the one-off DVD feature in FCPX would be great for test screener DVD’s…
    FCP Guru
    http://www.fcpguru.com
    Mikey Bouchereau replied 14 years, 9 months ago 2 Members · 1 Reply
  • Mikey Bouchereau
    December 5, 2011 at 3:38 am
    Hey Matt,
    If you use more than one computer to render any files through qmaster, the media will need to be copied over to the additional computers to be encoded also. You can change your shared cluster storage, this is where it will put all temporary files.
    Mikey B!
    Follow Me On Twitter!
    Check Out My Sky Replace Tutorial
