Activity Forums Adobe Premiere Pro export to dv tape – choppy, sound loss
  • export to dv tape – choppy, sound loss
    Posted by Rhitu Basu on May 12, 2005 at 9:02 pm
    When exporting to dv tape (Premiere Pro 1.5, Panasonic dvx100A via Firewire) the resulting movie looks choppy in parts and the sound will even dip in and out.
    My specs
    – machine : 2.56GHz CPU (laptop)
    – external drive : 250G, 7200 RPM ATA drive over USB 2.0
    – camera : Panasonic dvx100a, over Firewire (for capture and export-to)
    – Premiere Pro 1.5
    The footage captured fine (24P) – no dropped frames. I just can’t get it to export to tape properly – ie. without coming out choppy. Is my CPU speed too low ? Is the fact that the drive is external a problem, or that it is over USB (will switching to Firewire make a difference here) ? Are there certain Premiere settings I should be using ?
    I’ve tried some things recommended on this forum already – like manually recording instead of using device control – to no avail. Please, please, please help.
    Mike Velte replied 21 years, 3 months ago 2 Members · 2 Replies
  • Rhitu Basu
    May 12, 2005 at 9:07 pm
    By the way the “movie” in question is just a 5 minute student short. I did use some effects – brightness/contrast, color adjustment rgb & the hue/saturation one. There are also some fades, titles (5), and speed adjustments on a couple of the clips.
  • Mike Velte
    May 12, 2005 at 9:14 pm
    Exporting involves the hard drive reading 2 files at the same time, video and CFA, much more difficult than capturing.
    A nearly empty, well defragmented IDE drive with a fast CPU might pull this off.
    While USB 2 specs out faster than Firewire, it dont happen in real life.
    Try configuring (Preferences>scratch discs) CFA files on the system drive and try again.
    Failing that, add another internal drive or try a firewire external. Your CPU “should be up to it”, but it will work hard.
