Activity Forums Apple Final Cut Pro Legacy Export to Compressor – No options
  • Export to Compressor – No options
    Posted by Tom Kelly on October 29, 2009 at 11:44 pm
    We’re trying to export a sequence from FCP (v6.0.3) into Compressor (v3.0.3) just like we did yesterday. However now, the target, destination choices are grayed-out. Any suggestions on this?
    Tom
    Tom Kelly replied 16 years, 11 months ago 2 Members · 3 Replies
  • Grant Strac
    October 30, 2009 at 5:34 pm
    Quit and restart FCP then open project and right click sequence from Browser to choose export>using compressor. if that does not work hit command-3 or activate the sequence in timeline and file?export using compressor, if that does not work hold down option and double click the sequence to activate it into the viewer then file>export using compress. hope that helps
    Grant Strac
    Apple Certified Final Cut Trainer
    Apple Certified End User FCP6/7,Motion3,DVDSP, and Soundtrack
  • Tom Kelly
    October 30, 2009 at 6:33 pm
    Thanks Grant, we’ll give that a try. Guess its not worth asking why this happened….
    Tom Kelly
  • Tom Kelly
    October 30, 2009 at 6:52 pm
    Well Grant, that didn’t do it. As I suspected, if selections are grayed-out in one method of Export to Compressor, it’ll be grayed-out in another method of export.
    Might it be a Plist issue? Recently I had Motion act up and the suggestion to just trash Motion preferences worked.
    Tom
