Activity › Forums › Apple Final Cut Pro Legacy › export to avid meridian with fcp 5.1.4
  • export to avid meridian with fcp 5.1.4
    Posted by Couryc on September 5, 2007 at 2:15 pm
    Hi there,
    A client came to me with a couple of .mov’s in DVCPRO HD at a resolution of 1248×702. They imported fine into FCP 5.1.4, but then we had to export them for the editor who is on an Avid. The problem is, that when I try to do a quicktime conversion to the avid meridian uncompressed codec, it gives me an error that states “File Error: Unknown Volume.” On the flip side, when I just simply try to do the conversion in quicktime alone, it gives me an error that says “qtKitErrorCatchAll (-2014)”
    Any ideas? If you need any other info, I can provide it.
    Adam Smith replied 19 years ago 4 Members · 8 Replies
  • 8 Replies
  • Chris Borjis
    September 5, 2007 at 3:22 pm
    [CouryC] “DVCPRO HD at a resolution of 1248×702.”
    Thats not a DVCPRO HD resolution I’ve heard of.
    It should be 960×720 or 1280×1080
    Try to export it as that size with quicktime conversion and see what happens.
  • Michael Hancock
    September 5, 2007 at 4:34 pm
    The Avid Meridien codecs are standard def. If your frame size is any different than 720×486 (or the PAL equivalent) it will give you a cryptic error and won’t work (as you’ve found out).
    You’d do best to export a Quicktime Animation, Uncompressed, or png or targa sequence for import into their Avid. It will kill your Avid import time, but it’ll work.
    Michael.
  • Chris Borjis
    September 5, 2007 at 8:40 pm
    Why couldn’t he export an Avid DNx HD codec?
  • Michael Hancock
    September 5, 2007 at 9:01 pm
    Because he’s taking it to a Meridien system.
    The Meridien system is hardware based and (as far as I know) doesn’t support the newest codecs. He’d have to update his system (read that as, “Throw it out and buy a new one”) to the software based Media Composer for DNxHD to work.
    Michael.
  • Chris Borjis
    September 5, 2007 at 9:42 pm
    ah. now I remember why I don’t support Avid. 😉
  • Michael Hancock
    September 6, 2007 at 3:39 am
    Wow! Those are fightin’ words! 🙂
    Michael.
  • Chris Borjis
    September 6, 2007 at 4:00 am
    I had to, it was costing me an arm and a leg LOL.
    the last system I had was a nubus media composer 6.5
    it worked great for offline though.
  • Adam Smith
    September 6, 2007 at 4:54 am
    [MHancock (promoboy)] ”
    The Avid Meridien codecs are standard def. If your frame size is any different than 720×486 (or the PAL equivalent) it will give you a cryptic error and won’t work (as you’ve found out).”
    Yup.. can’t create anything in Avid codec unless it’s spot-on.
    720×486 and Lower Field First usually gets it.
    How’d you even get the codecs to show up? I have FCS2 and while I installed the Meridien codecs for quicktime just the other night, nothing I could do would make them show up as options for quicktime or motion output.
    Video Photographer / Avid Editor / FCS2 Neophyte
