Activity › Forums › Apple Final Cut Pro Legacy › Export to apple pro res from FCP..jaunty footage
Posted by Charles Lindsell on January 30, 2011 at 2:56 pmWhen i export my footage to apple pro res from fop the footage is jaunty at times. very annoying ! I need to maintain the quality though. any ideas why > My computer is fast and has plenty of memory.
David Roth weiss replied 15 years, 7 months ago 3 Members · 4 Replies -
David Roth weiss
January 30, 2011 at 6:07 pmPlease be a bit more precise if you will, otherwise we cannot give you the precise help you’re looking for.
What precisely were your steps and what precisely were your footage and sequence settings before trying to export to ProRes?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Charles Lindsell
January 30, 2011 at 9:11 pmits h264 footage shot on the 7d. I stupidly didn;t convert the files when editing. i know there not good files to work with. but is that the reason for the jaunty export ?
David Roth weiss
January 31, 2011 at 3:59 am[Charles Lindsell] “i know there not good files to work with. but is that the reason for the jaunty export ?”
Absolutely!!! Whatever jauntiness there may be is undoubtedly caused by editing the Canon material in it’s native form. Once you transcode your material, you’ll quickly realize that editing ProRes is a real pleasure.
Admittedly, FCP should not let any editing proceed with such non-editable video formats, but the problem is that we are being bombarded with new formats at a rate that is virtually impossible to keep up with. FCP is very old software at this point, and rather than try to fix the current version so it will do everything, it appears Apple is working on a major rewrite, which frankly seems like a better idea to me.
David Roth Weiss
Los Angeles
