Activity › Forums › Apple Final Cut Pro Legacy › Export to an HD Quicktime from Final Cut Pro
Posted by Katy Clore on June 2, 2011 at 5:12 pmFor some reason I am unable to export my sequence to an HD Quicktime. It only exports a portion of my sequence. Depending on the format of the quicktime, the length varies, but the size of the export remains the same (1.61GB). I can export to H264 and other formats as well as SD Quicktimes, just not an HD Quicktime. Has anyone encountered this problem? Any suggestions?
Rafael Amador replied 15 years, 3 months ago 6 Members · 12 Replies -
Shane Ross
June 2, 2011 at 5:20 pmWhat format are you working with in the sequence? CODEC? How are you exporting? H.264, FYI, is an HD format. All the Apple Movie Trailers are H.264.
If you go FILE>EXPORT>QUICKTIME MOVIE…and choose SELF CONTAINED, FCP will export a file that is your entire sequence, and in the same codec as that sequence. Make sure you mark IN and OUT where you want the movie to start and end.
Shane
Read my blog, Little Frog in High Def -
Jerry Hofmann
June 2, 2011 at 5:20 pmWhat are your sequence settings, and what is the format of the source material?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Katy Clore
June 2, 2011 at 5:46 pmframe size: 1920×1080 (HDTV 1080i (16:9)
pixel aspect: square
editing timebase: 23.98 (reason: changed sequence settings to match getty stock clip settings)
compressor: appel prores 422 (HQ)The individual source material is from a stock video site, so the individual clips have different settings.
Jerry Hofmann
June 2, 2011 at 6:23 pmMy guess is that it’s having trouble with one of the render files or one of the stock files… might re render it all. None of it was prores to begin with, right?
Jerry
Current DVD:
Dino
June 2, 2011 at 6:54 pmHow much space is left on the drive you are exporting to? Can you try exporting to a different drive?
Katy Clore
June 2, 2011 at 6:57 pmI’ve tried exporting everywhere. That is not the issue. Thanks, though.
Katy Clore
June 2, 2011 at 7:01 pm5 getty clips were apple prores 422 (HQ), pond5 were mixed… H264 or photo-jpeg, and ThoughtEquity which were photo-JPEG
Jerry Hofmann
June 2, 2011 at 7:26 pmProbably need to transcode the files which aren’t ProRes to ProRes… conform the sequence and try it again.
Jerry
Current DVD:
Brian Wells
June 2, 2011 at 7:56 pmNot to bring the question or discussion down too far, but since I didn’t see a direct answer to his reference, I’d at least hang a quick +1 on Shane’s post by double checking that:
a) The Timeline is completely free of In and Out points (the old Alt-X cure), and/or
b) Any In and Out points in the Timeline are exactly where you want your exported clip to start and end.
Katy Clore
June 2, 2011 at 8:56 pmExported both ways. One with no “in” and “out” points. The other with an “in” at the beginning and an “out” at the end. Neither worked.
