Activity Forums Adobe Premiere Pro Export time in CS6 – one sequence only
  • Export time in CS6 – one sequence only
    Posted by Gary Arrington on February 2, 2015 at 8:10 pm
    Recently I shot an all-day seminar. After importing all the files to PP CS6, I divided the material into 6 sequences, each about 55 – 59 minutes long.
    Each sequence takes about 2 hrs. to export, except for number 5, which takes about 7 hours! All the graphics are the same, the sequence settings are the same, same transitions, same everything as far as I can tell. Any ideas why this one sequence would be so slow?
    (I’m queuing all the files in the export settings window and letting Adobe Media Encoder run all night.)
    Gary Arrington replied 11 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
